joebedford wrote:
As I understand it, the override also puts fill battery voltage on the motors. When in sync'd mode the motors don't get full voltage and may not be able to overcome some resistance.
Just yesterday my bedroom slide wasn't fully closing. I discovered that one of the rubber wipes was getting wrapped around a bottom roller - I cut it away and end of problem (except for the fact that part of the wipe is missing).
The always get full voltage. What you may mean is, the AMP kick out is gone in override mode. Override supplies direct power to each motor and bypasses all other control functions. Doug
