GATJcampers wrote:
With no load on the rv and the batteries still connected I set clamp to DC amps and got .45. Batteries still at 12.1. I understand you say it can take days but I've done that and they are just not charging. I'm sure some of that is my lack of understanding but it just doesn't seem like the panel is any help.
I do have a volt meter also.
If you remove the panel from the battery and short the panel terminals together then what is the amp reading on the meter? s/b close to 5 amps at noon or the Isc rating.
