evy
Apr 16, 2016Explorer
sodajerk wrote:
Looks good. You might size your water tank closer to the size of your grey tank. 30 gal vs 18 gal. I can store some extra motor oil, bug spray, and such under the drivers seat. Also see what you can stash in the engine compartment, I have a little box for a funnel, some rags and extra fluids. Be sure to keep your fresh water hose separate from your sewer hose. I know you are only dumping grey water, but it can still be yuck. You could use a smaller hose for the drain. No solids. Look at hanging some pvc pipe under the van for that storage.
thanks guys if you click on the pictures you can go directly to my photobucket and look at all my other pictures from the start.
Sodajerk you want me to downsize my 30 gallon water tank?
I you look at my plan, I will add a 24"wide x 16"deep x 48"high metal box on my hitch,with the generator, pipes, extensions, adapters etc... I guess I could add some of the things you were mentioning (keeping the clean water hose seperate).
Thanks for that pvc pipe idea, tomorrow I will look under the van to see where and what lenght? If I can fit a 4"diam x 36" long pvc pipe with screw on cap I could store my two 10' long sewer hose.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
