BFL13's avatar
BFL13
Explorer II
Oct 27, 2017
More WFCO Woes
Friend with new to her 2008 Class C called saying while camping with grand-daughter and some dogs, with hook ups, the lights are dim and going dimmer back and forth.
So I as an rv.net trained "tech" am off to the rescue! :)
120v intake was ok, output at the converter was 11v sometimes 8v. Disconnected the single (new) 12v battery (voltage 10.6--yipes)
Lights in rig still work, so converter is working--but lights still going even dimmer at times then brighter. I have no clue how bright is normal with her rig. Still 11v and 8v at times, so converter has to be the culprit.
Attached my PowerMax adjustable voltage converter with wire clamps, set to 13.6v to battery wires in her rig. Ta da! Lights now very bright. Also now getting four lights instead of just three on the idiot light battery monitor.
Ok detached the PowerMax, installed a charged up 12v batt I took along just in case---lights still bright, re-attached the PowerMax at 13.6 and the lights went a little brighter. All is good!
So it seems the WFCO is having problems. It works with no battery and you get some voltage--11 or 8 so it seems like it is working but acting up a bit and the lights are really dim. BUT obviously the thing is not working right at 11v or 8v
So the plan is to get that WFCO out of there when she gets back and replace it.
I found it to be very confusing at first, that the WFCO was working with no battery so I suspected the battery, but the voltages were just too low and it kept dropping from 11 to 8 back and forth, with no battery at all, so it had to be the WFCO converter at fault.
(I have since recharged her battery and will get mine back and the PowerMax in a later swap)
Having RV issues? Connect with others who have been in your shoes.24,284 PostsLatest Activity: Jul 20, 2025
