time2roll
Mar 27, 2015Nomad
I believe you are limited to three panels by Voc unless you choose Midnite 200. Or some would have to be in parallel :(
My MS-MPPT-60 operates just fine without the display. I really like the custom programming available on the MS-MPPT-60 and I hope the Midnite 200 has similar. The programming I like is a short absorption time when the battery is mostly full charge and longer absorption when the battery has been drawn down. Need to connect a PC computer to do the program flash.
Good luck
Good luck
