JiminDenver
Mar 29, 2015Explorer II
The plan is to wire for parallel and run test in both. In parallel I gain the advantages of tolerance if shade is on one panel, better efficiency from a lower Voc to 12v and less heat at the controller. Switching to series in extended lower light situations may prove better then.
