brulaz's avatar
brulaz
MorRyde HD Shackle Upgrade
Anybody have experience with the MorRyde HD Shackle upgrade kit?
There's a great sticky here about using the Dexter EZ-Flex and wet-bolt kit:
RV.NET Dexter EZ-Flex sticky
But I don't want the rubber equalizer because: $$$, already have shocks, could reduce my already low tire clearance of 2.5". So will use existing equalizer.
One of my existing shackles after ~9000 miles.
Cheap Al-Ko 5200# suspension.
  • Well, found a local, S. Ontario, Canada source for HD shackles, bronze bushings and wet bolts.
    http://www.cerka.ca/catalog/32KIT.asp
    The top three are their own kits with equalizers.
    The bottom three are Dexter's.
    But as my equalizers are not one of those in the kits, I got them to substitute six bushings for the two equalizers and drop the price $20 to Can$102.75. This makes it just like the MorRyde kit using the existing equalizers. And cheaper as no shipping/border hassles. Cerka is located in Milton ON and has lots of other trailer parts, like bearings and seals.
    Now all I gotta do is get them installed. We might just get this done before heading to Florida after all.:)
  • ford truck guy wrote:
    I just upgraded my shackles and bolts to the Mor/Ryde HD and wet bolt kit... The shackles are almost twice as thick as the stock....
    Yes that's why I want them.
    Did you do it yourself? If so any suggestions?
  • I just upgraded my shackles and bolts to the Mor/Ryde HD and wet bolt kit... The shackles are almost twice as thick as the stock....
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
