K_Charles
Dec 14, 2016Explorer
If you drain the tank and then run the pump until there is no water before you pump the antifreeze in with the pump, there is no water in the line from the tank to the pump.
We just blow out the lines and put the pink stuff in the traps.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
