The_real_wild1
Dec 14, 2016Explorer
Drain the tanks, and open all taps. Run pump and drain hot water tank. Basically get every drop out of the lines, tanks, toilets, shower etc. Remove intake hose from water pump and hook up winterizing hose between pump and antifreeze jugs. Turn pump on and go to each tap. Open up until pink flows. Do everything including outside shower. Don't forget hot water tank bypass.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
