larry_cad
Mar 03, 2023Explorer II
The No Co error is triggered when your fridge does not produce refrigerant for 2 hours. When your fridge does not produce refrigerant, this means the boiler is overheating. An overheating boiler not only warms the food in the fridge, it is what causes the fridge to fail.
The first time the “no co” fault code appears on the optical control assembly, it can be cleared by the user by turning the refrigerator OFF and then back ON. This gives the user the opportunity to check for problems that may have caused a "no co" code, such as obstructed ventilation. This fault code occurrence is then stored in the controls. If the refrigerator completes a full cooling cycle after the user turns it back on, this fault code occurrence will be cleared from the controls.
Second "no co" Fault Occurrence
If the refrigerator does not complete a full cooling cycle after the user turns the refrigerator back on and the "no co" fault displays, the control locks the heat sources and a "hard-wire" power board reset is required. The hard-wire reset of the power board must be performed by a service center according to Norcold if you are not qualified to preform this task.
Sounds like the service shop messed it up. Good luck.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
