BFL13
Aug 14, 2018Explorer II
With no shading, I had my three 100w panels in parallel with MPPT and also tried with them in series with the MPPT. Made absolutely no difference to amps to the battery in full sun.
With shade coming in where the shadow from the trailer (ground mounted solar) started across the array from one end late in the day, I started to lose amps to the battery.
I chose to be in parallel for that, since I kept more amps coming in from the remaining part of the array, whereas being in series meant losing more sooner. The shadow was at an angle somewhat moving across, so it might have been a race between what diodes could do for you and what keeping unaffected panels going does for you. You still have diodes in an affected panel even when in parallel of course.
Perhaps it is another of those things that "depends".
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
