DutchmenSport
Jan 08, 2014Explorer
If you're using the standard scissor jacks, you really do not have to mount them ate all. Just extend them by unscrewing and one end on the ground and the other under the frame. Tighten and the affect will be the same as if they are mounted. Mounted jacks are "mounted" for convenience. It is a bit of a challenge to unscrew (open) them up unless they are fastened onto the frame. But if you don't mind wrangling them a little, you don't need to mount at all.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
