Salvo's avatar
Salvo
Mounting solar on rubber roof
What's the best method in securing solar on a rubber roof trailer? This will be a flat install. Z-brackets are already ordered, but if there's something better...
It is for my son-in-law's new toy hauler.
Sal
  • I always thought those single screw Z brackets were pretty iffy. I made my own using 1/8"x2" Aluminum Angle Iron 2" wide each. 2 SS screws into each at roof, drill 1/4" hole in side of solar panel frame and use 1/4" SS bolts to the angle iron.
  • Hi Sal,
    I'd make ever effort to find the "rafters" and screw into them, using liberal amounts of dicor. That is how my panels are fastened. I used three screws per side with angle aluminum to "stiffen" the panels.
    If it is a new unit the maker should be able to provide measurements for the rafter placement.
    I hope your son is excited!
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 17, 2026
