For those of you with rooftop solar, how do you mount the panel to avoid leaks? How do you route the cable? Where do you put the controller? Where does it actually wire in (which side off th...
Might not be for everyone, but I have had great results using Extreme Velcro to hold panels on a fiberglas truck topper and an aluminum topped travel trailer. Love the "No hole" system and they could be removed and used as portables, although I have not done that. I like to try different things than most.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
