waynefiExplorerFeb 04, 2019Mounting solarFor those of you with rooftop solar, how do you mount the panel to avoid leaks? How do you route the cable? Where do you put the controller? Where does it actually wire in (which side off th...Show More
time2rollNomadFeb 05, 2019Dicor seals the holes.Cable routed down the fridge vent.My controller is in the front storage compartment.Wired direct on the battery terminals.Suitcase solar would be too small and a pitn the entire time I camp.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
Related ContentSolar Panel Mountsmounting my solar panelsAnother solar question.Solar Panel MountsHow are your solar panels mounted?
