waynefiExplorerFeb 04, 2019Mounting solarFor those of you with rooftop solar, how do you mount the panel to avoid leaks? How do you route the cable? Where do you put the controller? Where does it actually wire in (which side off th...Show More
time2rollNomadFeb 05, 2019Tape is great to a solid surface such as fiberglass or aluminum.I would not trust tape on my rubber roof.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
Related ContentSolar Panel Mountsmounting my solar panelsAnother solar question.Solar Panel MountsHow are your solar panels mounted?
