waynefiExplorerFeb 04, 2019Mounting solarFor those of you with rooftop solar, how do you mount the panel to avoid leaks? How do you route the cable? Where do you put the controller? Where does it actually wire in (which side off th...Show More
deltabravoNomadFeb 05, 2019Here's my solar insallationDicor under the mounts, mounts screwed to roof, Dicor over the mounting feet / screws.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 30, 2026
Related ContentSolar Panel Mountsmounting my solar panelsAnother solar question.Solar Panel MountsHow are your solar panels mounted?
