Old-Biscuit
Jun 25, 2017Explorer III
1st off......
Screws do NOT hold in aluminum studs/rafters
That is why they are bolted or welded
Brochure states
6-way fully welded "aluminum cage" construction
5" welded aluminum truss roof rafters w/ 3/8" decking
Welded aluminum framed fully laminated 2" sidewall
Securing a TV mount to ceiling or even wall with be difficult due to the screws NOT holding in aluminum
Now if you were to mount it to wood cabinet :H
Sorry don't have good solution other then removing a ceiling panel and building a wood support to screw into.
2004 Dutchmen Colorado see pg 11
Brochure states
