Old-Biscuit
Jun 25, 2017Explorer III
Bet the end cap is NOT aluminum studs or wood blocks are installed for ladder mounts
As for frames etc......not much load bearing so screws will hold but can strip out very easily.
Weight capacity/Load bearing requires nuts/bolts or welding when aluminum is used
