dougrainer
Jun 25, 2017Nomad
Old-Biscuit wrote:
Bet the end cap is NOT aluminum studs or wood blocks are installed for ladder mounts
As for frames etc......not much load bearing so screws will hold but can strip out very easily.
Weight capacity/Load bearing requires nuts/bolts or welding when aluminum is used
Sorry, I rarely disagree with you. But, on this you are wrong. Use NON self-tapping screws when securing to aluminum. That way you will have screws that will tighten and stay tight. Doug
