jayspi's avatar
jayspi
Mounting TV on roof of RV with Aluminum studs
Hi, we have a 2004 Colorado 33RL 5th wheel. It is new to us, and we were told that the studs are aluminum.
I'd like to root mount a TV on the bedroom. There's a large window that is keeping me from wall mounting it. However, I'm not sure if the studs would support it, and, if they do, what type of screws to use.
The TV itself isn't heavy. It weighs about 5 pounds. Any suggestions?
Thanks!
  • Ivylog's avatar
    Ivylog
    Explorer III
    Use a stud finder to find the rafters and then drill a small hole into one in the area where you plan to mount and see what comes out...doubt it will be alum. Wood screws will work in alum.
  • If you remove a ceiling vent fan bezel you will probably be able to see the rafters. I've seen aluminum/foam panel walls with wood rafters. My 2000 FW has alum studs and alum rafters.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 19, 2025
