We have a 32" TV that we are presently taking down while we travel. How have others installed a TV permanently ?? Is it safe to use the screws on the back of the TV, or do I need to somehow hold the...
This is a 32" LED/LCD screen (probably about 10 lbs) mounted on an articulating arm mount with tilt. I bolted the arm mount through the plywood backer board and attached the backer board into the studs in the wall using glue and screws. The backer spans three studs. I do nothing special for transportation but may install a strap if I anticipate long distance on rough roads.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
