wa8yxm
Mar 05, 2019Explorer III
enblethen wrote:
I would not put lead acid batteries inside the rig. They give off gases.
Your temperature ranges are not that extreme. Keep them charged with a good quality converter.
Ditto.. Lead acid batteried are good from over 40 below to around 200 or more The higher temp is often found under the hood of a car when running.. the lower one..> Well my car would not start because the ELECTRONICS did not work at -40.. but the battery cranked just fine.
Now For this I am speaking of starting batteries. but the DEEP CYCLE are .. very much the same temp range.
And what Enblethen said about the gasses given off by the battery in normal operation.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
