djousma
May 18, 2018Explorer
Dutch_12078 wrote:djousma wrote:
One other comment about Dish(and Directv) and the Winegard Traveler. That satellite dish is a single satellite dish. meaning it can only receive a signal from one of dish satellites at one time. Dish programming comes in on 2 or 3 satellites. If you have two "wally's" connected, the primary one is what controls the dish position based on the channel selected to watch. the secondary wally will be at the mercy of the primary, in that the secondary can only tune into channels that are available on the satellite that the dish is currently tuned into. Even if the primary is not being watched, the secondary cannot command the dish to move to the other satellites.
The only way around this is to install this type of dish: Linky
That is RV portable, but when deployed works like home dish and can receive all dish satellites at one time.
The Dish version of the Winegard Trav'ler (SK-1000) is an automated RV mounted Dish residential 1000.2 triple LNB dish and receives all three western arc sats at once. It works quite well with all Dish receivers, including the latest Hopper3. The SK-1000 is what your link shows.
Dutch,
You are right. I was mistaking it for the lesser Carryout/Playmaker/Pathway series. I'm going to go ahead and remove my post, so as not to confuse the OP.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
