dougrainer
Jun 22, 2020Nomad
wopachop wrote:
Now if I pull the thermistor completely off the cooling fins, shouldnt I see fridge temp get very low before it cycles off and allows temps to rise?
Possibly, Some Control boards react differently. There is a resistance/Ohm signal from the Thermister and if out of normal range may cause malfunction of the Cooling cycle. On Norcolds, if you disconnect(unplug) the Thermister, it will cause a BOS cooling cycle. This causes the refer to alternate between cooling and shutting off at timed intervals. But, for a lot letting it hang down will cause 24/7 operation, until the refer Thermister gets cold enough if that is possible. Remember, The Thermister senses the FIN temp, not the air temp. The fin temp will be 10 degrees colder than the actual refer temp. No harm in trying, post what happens. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
