wopachop
Jul 15, 2020Explorer
I was thinking about the out of normal OHM range. But even if that existed for my model it would be towards the benefit of cooling.
When you first start the fridge it will be ambient temps. So the probe will send that OHM signal. Fridge cools to 38F. Now with the probe off the fins, should the cooling continue to get much cooler? Since the probe is normally reading the fin temp that Doug described as being 10 degrees cooler. I would think a probe hanging in the air would have to read around 28F to send the correct OHM reading to shut down.
My particular dometic fridge does not have the temperature setting dial. But i still enjoy reading about other models and how they act. I want to find the OHM specs and test my probe.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
