pianotuna
Jun 08, 2013Nomad III
Hi pnichols,
Everything I've read suggests that wider tires have less rolling resistance than narrower ones. The brands I'm considering are Michelin and Toyo.
pnichols wrote:
Don,
I'd recommend looking at going to a Load Range E 215/85R16 set of tires - I did in the summer of 2011. This is actually a taller tire (about 1.2 inches larger diameter than the stock 225/75R15 size), so you wind up with about 0.6 inches of more ground clearance. The load versus pressure ratings are identical for the two Load Range E tires. The tread width is about 0.5 narrower with the 215/85R16 size, so you get better air cooling between the rear duals. If you get Michelins, you also get slightly better gas mileage from their 215/85R16 tires because they have less rolling friction.
Think about it, unless you really need the higher load capacity of the 235's!
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
