pianotuna
Jun 12, 2013Nomad III
Hi pnichols,
The batteries and solar were part of the modifications I've made.
I have added:
4 marine batteries (8 in total including the starter battery)
1 set of braces welded under the compartment I "gave up" for battery storage
4 unisolar panels 256 watts total
2 switches to allow bank selection for charging from solar
1 blue sky 3024di controller with added switch to trigger equalization without disassembling the case.
2 hall effect ammeters
1 additional charging path from the alternator
2 switches to manually control the alternator house battery charging with continuous duty solenoids.
2 automatic circuit breakers to replace the charging path fuses
1 2500 watt msw inverter (next on the list for an upgrade)
2 perko switches to turn off DC power to the inverter (one for each bank)
1 30 amp female outlet powered by the inverter
1 dedicated inverter outlet in the kitchen
1 new rear bumper made from 3/8 steel u tubes this includes a 2 inch receiver
1 roller for tail drag prevention this fits in the OEM 2 inch receiver
2 auxiliary shore power cords (one for converter with two extra outlets, one for the water heater with one extra outlet)
1 energy monitor for monitoring all AC power
1 120 volt outlet in the waste tanks area
1 120 volt switched outlet in the pass through storage
1 120 volt switched outlet in the storage for the water hoses (used in winter time to keep the hoses flexible)
1 120 switched outlet for antifreeze protection for under the sink use
1 fan to blow warm cabin air under the sink
1 heater rod (40 watts) for plumbing to bathroom
1 220 volt incandescent bulb for water pump anti freeze protection
1 charge wizard
1 heater for the waste tanks (100 watts)
2 mechanical thermostats for anti freeze protection (waste tanks and under kitchen cabinets)
1 heater for the pass through storage (100 watts)
2 thermocube TC-3
2 fans in a mask on the fridge chimney thermostatically controlled with added off switch
1 25 watt light bulb in the exterior of the fridge to prevent low temperature freeze ups
2 small surge suppressors--one for the converter and one for the fridge.
1 adapter for the bathroom sink so I can use a water hose with the tank rinse when there is no water at a dump site
1 trik-l-start
2 volt meters
1 scangauge II
1 set air tabs to try to save on fuel. They do cut down wind noise dramatically and when driving with the wind seem to improve mileage. Heading into the wind--there is little difference pre tab and after tab. But the reduced noise was worth the effort.
I've done some no cost or low cost mods such as adding a sleeping bag for insulation over the passenger's side duals (bare metal with no covering at all was the OEM). I could not do the same on the drivers side as there were propane tubes and Romex laying on top. I did manage to wedge in some 1/8 foam. I also disconnected and shut off the outdoor shower. I taped off the holes and filled the compartment with some foam to add a bit of insulation.
In addition all but three of the 120 volt outlets have been replaced with units that would pass code--and extra outlets have been installed where I wanted them.
I have pretty much run out of things to improve on. I'd love to add to the insulation in the floor (spray foam from below?). I'd consider a 2nd alternator. I'd consider upgrading the Blue Sky so it would do up to 20 amps of diversion loading to run a 12 volt "in the drain" water heater element. A remote switch for the inverter would be nice--but the entire inverter is on the "upgrade" list.
I have added:
1 charge wizard
2 thermocube TC-3
1 trik-l-start
2 volt meters
1 scangauge II
pnichols wrote:
Don,
In the description of your RV above, did you forget that huge battery bank in it and all that solar on the roof ... or am I thinking of another RV of yours?
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
