pianotuna
Jun 13, 2013Nomad III
Hi pnichols,
256 watts.
I've tried to eliminate generator use. Because I have dual charging paths I can draw 70 amps from the alternator for the house batteries if they are "hungry".
I'm a certified propane miser using less than one liter per month. That will be changing this fall as I'll be semi full time in winter conditions--often with no shore power or at best a single 15 amp circuit to draw from.
256 watts.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
