ScottG
Feb 17, 2020Nomad
Cummins12V98 wrote:Lwiddis wrote:
“I don't believe there are any 220 volt items running off the 50 amp system, I hope.”
Nope. Not a one running 220 volts. Basic RV electricity - “Although a 50 amp service for a recreational vehicle, or RV, is connected to four wires and uses a four-prong plug, it is still a three pole service with only hot, neutral and ground connections. It is different from a conventional 120 volt service in that there are two 120 volt hot feeds, or legs, each at 50 amps.”
Interesting. I have 220v clothes washer AND dryer. I have a standard 50A service. Mine is wired with four wires. Mine uses ALL four wires.
Maybe I gotz a special one???
Nah, there are some newer rigs using 220V for stuff. It's becoming more common and why not?
If I were to install my own W/D in an RV, I would go either 220 or propane.
