wa8yxm
Feb 18, 2020Explorer III
Spade Cooley wrote:
I don't believe there are any 240 volt items running off the 50 amp system, I hope.
YOu should have only one Double breaker (220 volt) in that 50 amp rig.. The MAIN. all the branch breakers will be single (120 volt).
IF there is a device in the rig that needs 240 volt. Well there is a list of "Suspects" as they say
Some 50 amp RV's have an Intelletec EMS.. if there is a signaficant (IE 200 or more )volt difference between L1 and L2 it goes to sleep cause you are on 50 amps and there is nothing for it to do. on 30 amps there is no differential worth mentioniong between L1 and L2.. NOTE it does not use 240 volt. Just looks for it.
Some modern "All ELectric" RV's may need 240 volts for things like heat (room heat) or cooking I stress the word MAY. Or for a cloths dryer.
But most do not.
And if you have propane (For cooking and heat)
THen you are all 12 or 120 volt No 240 volt save for the optional EMS
SO your hope. is granted.
I live in a 50 amp RV and often am on 30 amps
The Rules accordding to Reddy Kilowatt
20 amps. I'd not run the A/C but you can run the MIcrowave (usually)
Water heater (OR microwave never both) Possibly.
Fridge and televisions and such no tribble. (And the converter for 12 volts)
30 amps the A/C and water heater OR microwave but never all three
50 amps "All you can eat"
NOTE Or Caution.. Space heaters (should you choose to use) tend to MELT the QuickBox outlets used in most if not all RV's (Unibox) I have had one get hot (did not melt I shut down too fast) and have seen melted ones both in photos and in person (I'm not an RV tech)
I installed a pair of 15/20 amp regular outlets, in boxes, like in a 1950's house (Before unibox) Each outlet has a dedicated breaker and 12ga wire wrapped around a screw and properly tightened.
NO "Aroma of hot wire".
