  • Here's an exmple of a 2 day period from Flaggstaff, AZ in April of this year 1/2 hour intervals using the PT100. 80a is the most that I've seen on the display during summer.
    I forgot to do a recording like this again during the summer while boondocking with 6.5kwh - 7.5kwh harvested days.
    Daily PT Data from that time period.
  • Doesn't look particularly well suited for RV application. For lithium application would like to see at least 600 vdc support on the battery bank.
  • pianotuna wrote:
    The Magnum 100 amp unit needs an input voltage of 72 to do 100 amps @ 12 volts.
    There must be some pretty big lugs on that controller.
  • Hi Mex,
    Nice!
    I see it does require at least a 24 volt battery bank with a minimum of 100 amp-hours.
    The Magnum 100 amp unit needs an input voltage of 72 to do 100 amps @ 12 volts. I wonder if this unit has similar limitations?
  • That's a big one. Surprised to not see any reference to Li charging.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
