mcheroExplorerMar 16, 2015MPPT Choice ??Looking to put 4 high voltage panels on the Discovery. Was just measuring and figured out that I could plut 4 panels on the roof w/o any issues. I was looking at the following Xantrex charge contro...Show More
time2rollNomadMar 16, 2015600 volts is pretty standard system rating for panels and MC4 cables.Controller will also have a maximum input voltage rating. My Morningstar will disconnect if panels get over 150 volts.Four panels in series Voc at 37.4 will be approaching 149.6 volts on the controller as the battery tops off. And a bit higher in cold temperatures.I would be a little close for comfort on a 150v rated controller.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
