time2roll
Jun 14, 2013Nomad
•Battery sense wires are now optional (the 2nd gen 3024 required them)
I see nothing fancy here. 3048 will just read what is available on the main feed wire. If you have a long run to the battery I think you will use the sense wire option.
This is what Morningstar does.
http://www.roguepowertech.com/blog.htm
IMO 3048 will just use the the higher voltage number between sense terminals and output terminals.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
