Salvo
Jun 14, 2013Explorer
I don't think it's that big a deal having voltage sense when current is less than 20A. Most people install charge controller close to batteries with good sized cables.
RV manufacturers on the other hand do a woefully inadequate job with both the location of the converter and size of cables. I had about 23 mohm line drop from converter to batteries. At rated current of 45A, I get a 1V drop across the cable. Charging was very slow. I opened the voltage feedback loop and added a sense line to battery. The charging performance of the 7345 was significantly improved. I added a diode to the circuit so that if sense line opens, the diode clamps max voltage to 0.7V above nominal.
Sal
Sal
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
