lorelec
Jun 14, 2013Explorer
My reference was to - That stuff with sensing battery voltage during a MPPT tracking function (as Sal described in an earlier post). Additionally to the question Almot asked previous to my last post. I assume you are sensing the battery voltage pretty much all the time unrelated to the tracking function. Are there two processors in the new unit?
Can you give us any update as to when the data sheet will be available for your new baby?
Yep, the battery voltage measurement doesn't have anything to do with MPP tracking, and the sense wires are always active if they're connected. Mode transition points and voltage regulation in constant-voltage modes rely on them.
There are two processors in the new controller.
Should have a spec sheet on it in the next couple of weeks...it's getting closer to the top of the list!
What are the triggers and new user options on MPPT??
The MPPT on this controller is still based on the dynamic tracking that the 3024 used, but it's much faster now. It still uses an array sweep to locate the initial MPP when coming out of rest and between some modes, and then constantly tracks it from there on out. In addition, the user has the option of triggering an array sweep at an interval of their choosing, which can be helpful for arrays that are often shaded. The array sweep is on the order of tens of milliseconds now, so it's basically transparent. The controller also features a slower MPP sweep that is triggered by a fast-rising battery voltage, which will help avoid overshoot common with small (and AGM) batteries. Plus some other tidbits that work behind the scenes to make the tracking more effective and accurate.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
