Salvo
Jun 15, 2013Explorer
As mentioned before, most people who install charge controllers in a RV are cognoscente of line drops and and know that a 1% drop is equivalent to losing 1% of PV power. The cable will be beefy. There will be minimal drop and no big deal in lost charge times.
As far as additional loads, well that's why I said 'in most cases'. They are usually short lived. Once you're in absorption, does it really matter if battery voltage is 100 mV lower when a heavy load turns on?
Perhaps you feel compelled to add sense because the big boys do it? You got a 300W max unit? I question if it's cost effective for lower power units to add a sense circuit.
My offer still stands to test your unit. Don't want to keep it, just offering to test and give you fair publicity if warranted.
I realize there's no ground sense line in my 7345 mod. It's not needed. About 80% of the line drop comes from the positive cable. I have a 23 ft MH, and my converter to battery cable is 23 ft long. It snakes all over the place. The ground on the other hand connects to chassis (a good sized frame) through a short cable. It's good. That's how many RV's are built.
lorelec wrote:
I disagree. The onset of absorption may occur too early if the battery voltage is not being measured correctly at higher currents. As well, if you have significant loads that the controller is supplying current to in absorb and float modes, the controller may be undercharging the batteries during those times. Believe me, I wouldn't go to the trouble of adding the feature if there wasn't any benefit of doing so. Also, you're missing the negative sense wire in your schematic a few posts back, so you're not compensating for the voltage drop across the negative battery wire in that design.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
