KJINTF
Jun 17, 2013Explorer
Exactly why MPPT controllers are rated at
Input Watts (P=I*E)
Higher voltage lower current same power
Just do not go above the rated input voltage value
and
output Amps
So a 45 amp controller should never be designed with more than a 600 watt array
So long as the voltage developed by the array is less than the controllers max input all is good. As you say anything more is a waste of money the controller limits the output current to it's max rating. Input watts and output current for MPPT
Input Watts (P=I*E)
and
output Amps
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
