BFL13
Jun 18, 2013Explorer II
"but you want to stay inside the 45amps limit.
Not really
You want to stay within the WATT limit on th einput side for the operational voltage 12, 24, 36, or 48"
Argggh! But you said if you go close to the 45 the controller will heat up and you want to stay well below that limit. Now you don't care if you go over the 45?
I meant just use bigger panels at the same Voc to get more wattage as one choice.
Not really
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
