red31
Jun 19, 2013Explorer
HiTech wrote:
You are into the part of the IV solar panel curve where the amps produced are essentially Isc whether at 14.8v at the panel, or at 15.3 because of the .5v drop due to wiring. There *is* a small drop since the curve is not flat, but it does not usually add up to much unless Vmpp under current conditions gets close to Vbattery.
Jim
If there was zero voltage loss wouldn't the panel be at 14.8 and not at 15.3 so there would be no loss? ie, in both cases you'd read the iv or power curve at the same spot?
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
