smkettner wrote:
Switching on amperage is rather imprecise while the RV is in use.
Example if you drop to float at 1 amp but the RV is using 2 amps you are back on the timer anyway.
That's why I set it to 2 amps while in use :) , and the timer to 90 minutes - seems more reasonable than 120, with my shallow cycling. This is when it usually drops to parasitic loads level, ~80-100 minutes.
While in storage, I change the current to lower value and don't bother to change the timer because the current drops so fast that it transitions to Float after few seconds in Absorption.
