BFL13
May 30, 2015Explorer II
full_mosey wrote:BFL13 wrote:
The title says "controller test" but I can't figure out what you are testing for. Maybe I missed something.
Test#3 is to sufficiently deplete the AGM thereby giving the MPPT a chance to produce power. I intend to compare the Kill-A-Watt's reading of WHs consumed by the Air Conditioner against the TPA's reading of WHs drawn by the MPPT.
HTH;
John
Do the TPA and the Kill-A-Watt use different constants?
Do you suspect something does not match from previous results?
You do good tests. I still have the info about AGM and high amp draws in mind that I remind folks about who want to run their microwaves, but only have room/weight allowance for two batteries.
