full_mosey
May 30, 2015Explorer
BFL13 wrote:
Do the TPA and the Kill-A-Watt use different constants?
Do you suspect something does not match from previous results?
You do good tests. I still have the info about AGM and high amp draws in mind that I remind folks about who want to run their microwaves, but only have room/weight allowance for two batteries.
Thanks for the complement.
I'm not sure what constants are.
Yes, I spent Thu and Fri setting up the test environment. On Thu there was a brief period of partial Sun where I tried the Air Conditioner for 3hrs . KAW recorded .87 KWH and the TPA recorded 412 WHs. Using the formula 50x + 550y = 870, I solve x as 3hrs fan time, or 150WHs, and y = (870-150)/550, or 720/550 = 1.3hrs of compressor time. Afterwards I discovered a warm connection which I corrected.
During these two days I also got comfortable with video capturing and I now know how many hours I can record.
I plan to report power in Watts and WHs as I do not have any capability of capturing AHs. It should be interesting.
HTH;
John
