full_mosey
May 31, 2015Explorer
First, I need to revise my connections from
SA -> fuse1 -> TPA -> fuse2 -> MPPT -> AGM -> MMS
to
SA -> sw1 -> TPA -> sw2 -> MPPT -> AGM -> MMS.
While I do have fuses, they are there to be used as switches during the testing. Therefor, sw1 allows solar output to reach TPA and sw2 allows TPA to pass solar output to MPPT.
Test#1 went well. I set sw1 on at 6:19 and started recording at 6:20. At ~24min into the run I began to set sw2 on/off to check for Amps.
Below is a log taken from the 54min video.
Time - Reading - Comments
00:00 - 26.43V 0.00A
20:00 - 35.42V 0.00A
24:18 - 36.14V 0.00A
24:21 - 24.21V 0.00A sw2 on
30:06 - 36.62V 0.00A
30:07 - 28.28V 0.00A sw2 on
33:38 - 38.12V 0.00A
33:42 - 28.63V 0.11A sw2 on
50:45 - 40.01V 0.00A End of test, 40V reached.
Time is video time, add to 6:20 for time of day.
TPA does not report lower that ~0.11A. I can see Volts drop at 24min.
'sw2 on' is only long enough to take a reading, otherwise off.
HTH;
John
to
HTH;
John
