halhawkins's avatar
halhawkins
MPPT/DC to DC Charger for Trailer Build
Hello all, first time poster.
I am currently doing a special purpose conversion of my enclosed gooseneck and am at the point to figure out electricity. I have a lot of 12V equipment, especially strip lighting that takes up more amps than shore power (coming from the generator) can provide. The 120v equipment/AC will use about 24a. The 12v equipment will use about 90a and each job for the trailer will be about 2 hours so a total of 180a will be used, so my idea was to use two deep cycle batteries as the main source of power with the batteries being charged while driving/hooked up to truck or when connected to shore power.
I thought a DC to DC charger like the Renogy DCC50S 12V 50A DC On-Board Input MPPT Charger would work but Renogy told me that using shore power with an AC to DC converter would not work with the device in lieu of solar power. So I am trying to find a device that would charge the batteries from 2 different sources. Its very unlikely that the 2 power sources would be used simultaneously to charge batteries (but possible?). I've put a rough draft schematic below to give you all an idea. Would love to hear your thoughts. Thanks very much in advance.
  • Hi,
    Two possible routes.
    1. get a hybrid inverter charger. These allow for load support. That means power may be drawn from the battery bank to make up temporary shortfalls in power.
    2. There are some inverter chargers that have 2 AC input sources.
    A side question. Why do your dc strip lights draw so much power, and what are they being used to light up?
    On my last trip I often only had 15 amp shore power with no access to the breaker panel. I set my hybrid inverter/charger to not draw more than 13 amps. When using the microwave I do see over 200 amps being drawn from the batteries.
    Be aware that "load support" is not "voltage support". To have voltage support one needs an autoformer.
  • "I have a lot of 12V equipment, especially strip lighting that takes up more amps than shore power or the generator can provide."
    You are using more than 90 amps for lighting? What are you lighting?
  • Grit dog wrote:
    So you’re planning on running shore power and generator at the same time to get your 24A AC power?
    On the DC side I’d think the converter would go straight to the batteries, not thru the DCDC charger.
    And you’re not going to pull enough power off your trucks 12V pin on the trailer plug to power a 50A DCDC or even a 30A DCDC.
    And you’re going to have to pull a full load on the converter to keep just 2 batteries alive for 2 hours pulling 90ah. Better get a big one. Or more/better batteries.
    No the generator is what is going into the shore power.
    Why couldn't two batteries with 115ah each handle 90a load?
  • So you’re planning on running shore power and generator at the same time to get your 24A AC power?
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
