KJINTF
Aug 19, 2013Explorer
MS TS-60 MPPT Solar Controller Data
I did a simple data grab earlier this afternoon and though I would post some of the results.
SURE would appreciate others posting their controllers results
The rigs setup - Four panels in a series parallel arrangement 2 each K135 and 2 each K140 panels - House batteries 2 Costco 6VDC CG 220amp rated - 3oo watt Suresine inverter - Trimetric 2025RV
Ambient temperature 93F - Fast moving clouds - House battery SOC 99% (Trimetric Reading)
19:20:37 to 19:21:38 a very smalll load on the house battery bank maybe 4 amps, 19:21:38 to 19:22:39 added a 100watt 110Vac bulb on the inverter, Added engine starting battery as a load and switched it off about 19:24:00, Clouds cam through 19:24:41, added back the 100watt 110Vac bulb
