KJINTF's avatar
KJINTF
MS TS-60 MPPT Solar Controller Data
I did a simple data grab earlier this afternoon and though I would post some of the results.
SURE would appreciate others posting their controllers results
The rigs setup - Four panels in a series parallel arrangement 2 each K135 and 2 each K140 panels - House batteries 2 Costco 6VDC CG 220amp rated - 3oo watt Suresine inverter - Trimetric 2025RV
Ambient temperature 93F - Fast moving clouds - House battery SOC 99% (Trimetric Reading)
19:20:37 to 19:21:38 a very smalll load on the house battery bank maybe 4 amps, 19:21:38 to 19:22:39 added a 100watt 110Vac bulb on the inverter, Added engine starting battery as a load and switched it off about 19:24:00, Clouds cam through 19:24:41, added back the 100watt 110Vac bulb
  • Salvo wrote:
    We're in boost for just a short time. It doesn't matter if controller is a couple of minutes longer in that mode.
    YOU may be, but others don't necessarily use their system the same way you do. Using solar as a power source and not just a battery charger, the controller stays in MPPT a majority of the day.
  • Almot
    Been reading your related thread and saw Marc's response - sure is nice to see him responding and clairifing many of the issues.
    I did several different tests one running 10 to 15 minutes while the controller switched between operational modes (the unit allows looging of the operational modes as well as many other things not graphed earlier).
    How about taking some measurements from your nice new controller and posting them?
    During the above graphed tests my battery bank was 99% SOC which makes what your asking is a bit difficult to answer. With a 560watt PV array and a "small" 220amp/hr battery bank. I personally do not have any issues with getting it fully charged even when drawing 20 or 30amps for external loads. Most times in the late afternoon I notice 13.2 to 13.6 battery volts being displayed by the trimetic.
    Look at the bettery voltage graph it stays a constant 14.5Vdc (or there about). I guess it was in either MPPT or ABS modes during the above graphed tests. Remember the displayed "Battery Current" is actually load current not the current the battery is receiving - for the above tests I did not log the Trimetric data which shows only the battery I/O current.
