KJINTF's avatar
KJINTF
MS TS-60 MPPT Solar Controller Data
I did a simple data grab earlier this afternoon and though I would post some of the results.
SURE would appreciate others posting their controllers results
The rigs setup - Four panels in a series parallel arrangement 2 each K135 and 2 each K140 panels - House batteries 2 Costco 6VDC CG 220amp rated - 3oo watt Suresine inverter - Trimetric 2025RV
Ambient temperature 93F - Fast moving clouds - House battery SOC 99% (Trimetric Reading)
19:20:37 to 19:21:38 a very smalll load on the house battery bank maybe 4 amps, 19:21:38 to 19:22:39 added a 100watt 110Vac bulb on the inverter, Added engine starting battery as a load and switched it off about 19:24:00, Clouds cam through 19:24:41, added back the 100watt 110Vac bulb
  • PT
    Not sure what you are referencing as "Boost"
    Graph #2 Simply shows the array current Vs Battery Current w/o the voltages involved - the top one shows Array Power Vs Battery (aka Load) Power - I have loads of additional data (temperatures, I/O voltages, etc..) but decided not to post it all at once. Wanted to see others post some of their controllers data so we can do a comparison.
    The last one shows even a short piece of #4 cable has losses
    This one has voltage and current but not the resolution
  • Hi KJINTF,
    Thanks for posting those.
    Does graph #2 indicate how many amps of boost there are from the MPPT?
