JiminDenver wrote:
West
These numbers came from the two panels and running the 5000 BTU air conditioner for four hours. I feel the three 250w panels flat will handle it mid day when we are likely to need it the most. I was going to window mount it but instead have decided to put it in the rear storage under the bunk, just open the storage door for ventilation while running.
AC on solar test
Thanks, Jim, I hadn't seen your posts there. I have a few ideas about mounting the AC, too. I'd use a window but all my new residential sliders are about two inches too small. It may go in the back, mounted up at the ceiling.
Have you had a chance to sun the AC on a warm day? Did the 5000 BTU unit keep the temps down inside? I'm just curious more than anything, my rig is built like a big foam cooler so I think a 5000 BTU unit will work well.
