DIVE2XS's avatar
DIVE2XS
Multi Inverter use
I have 3 inverters that I can use for my travel trailer. A 2000,1500, and 350 watt. Also 2-12 volt interstate batteries for storage.
It would be nice to use appliances en route or overnight. Use the refrigerator on electricity instead of propane while traveling from place to place or, microwave before disconnecting as long as the tow vehicle is connected and running to keep from having to connect and use my gas generators.
I can see using a small medical device for a longer period, say over night.The placement for this would be stationary in the bedroom.
Since using the refrigerator and microwave would be high usage, I'm guessing that the 2000 watt would be best for that as I would not be as concerned about energy usage. Placement for that would be in the kitchen area in the same area as the converter.
For the bedroom, I could run a 12 volt wire from the battery or hook into an existing 12 volt light and mount on wall in bedroom. I would use this separate as it uses less energy and would make the 2-12 volt storage batteries last longer.
I guess what I am asking is how to run/connect it all together and how to separate each inverter for the system for uses I envision.
Perhaps I have it all wrong and there is another way to do this?
Thanks for any help!
  • BFL13 wrote:
    I went all big inverter, but lately went back to using a small one as well. The big one is whole house, which includes the seldom used TV which stays on standby drawing amps unless unplugged. ...
    Easier to use a small inverter for phone charger etc, and turn off the big inverter except when needing it to do something temporary.
    My entertainment is turned off with a switched extension cord nicely hidden in a cabinet ( I don't like cord mess.) That can be a significant draw overnight. My big inverter is *never* off.
    With more than one inverter, your job is to keep turning them off and on as necessary. Not my style, but hey, if it works for you..!
  • My small inverter basically just runs. Large inverter is for temporary use of microwave or anything else large. Not a huge deal but gets turned off when not in use.
    Next RV will have a big lithium battery and I will not care so much either.
  • Hi,
    The alternator won't keep up because it "reads" the chassis battery. When that is fully charged, output drops. There are ways around that problem, such as adding an external diode for the "house loads" on the alternator. Too much trouble for me to bother with. A 2nd alternator would work well, too. But that is quite costly, and leaves one with a non standard serpentine belt.
    RLS7201 wrote:
    wa8yxm wrote:
    One thing I found when running an Absorption fridger on the inverter (That is an option in this RV) is that the alternator does not provide the house batteries with enough current to maintain them at that high a load. Sorry.
    Most RV fridges are 300-400 watt on A/C (And I also have some parasitic loads like the TV/Radio/Sat receiver (no more) and so on) The alternator could not keep up. Run it on propane and be happy
    Residential run 100-200 watts now days That it can handle.
    Or a high effiency (50 watts and it runs on 12 volt).
    Your alternator should be about 130 amps at 1500-1800 engine RPMs.
    If it won't keep up with 360 watts, you have a problem.
    Properly functioning gas coaches will keep up with running an absorption refrigerator on the electric heaters.
    Richard
  • BFL13,
    360 watts at what voltage? Many small inverters do not do 120 volts--that makes a big difference to heating device demand. (power (wattage) changes by the square of the voltage).
    Example:
    120 volts vs 110 volts. Wattage would drop about 16%
    360 watts x .84 =~ 302 watts
    That will still demand about 30 amps from the alternator--which just isn't going to happen with 'stock' equipment once the chassis battery is charged.
  • I got the 360-under 350 watts when starting the fridge from my inverter gen and reading from the Kill-A-Watt. Don't have the voltage now but would have been 124-122 ish.
    In this case it would be from an inverter, which will add amps as battery voltage declines over time to maintain the watts. A MSW inverter is ok for a heater, so you would need a special voltmeter to get that voltage.
  • I do not believe it was said whether the refrig was a household , 117 volt refig or a RV refrig, it will make a difference when allocating all those watts , volts and amps.
  • The alternator will make plenty of power for the fridge.
    The problem is the wiring. Your camper charge wire, through the 7-way RV plug, is only 12-gauge at the largest.
    The way to get enough power to the camper for running loads like a refrigerator or charging batteries a whole lot faster is to run a separate, large gauge charging wire.
    Sometimes I do this simply by buying a set of 25’, 2-gauge jumper cables and cutting the clamps off.
    Put lug terminals on and connect to your truck battery, run it to the trailer.
    Use an Anderson connector, it’ll handle 100 amps.
    Run similar cable to your camper batteries.
    It’s not a bad idea to put a 100-amp circuit breaker at the beginning of the cable near the truck battery.
    Getting DC power across wires at low voltage is all about wire size.
    Bigger is better.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
